AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Ice Maker not filling with water. Water dispenser works. Kenmore Elite
Ice maker cycles. No water fills the ice cube tray. You can hear the motor hum to fill. At first I thought it was a frozen line. I even put a tiny little heater at the bottom front of the fridge, where the water line splits to go to water dispenser or ice maker. This actually seemed to work for a few weeks. But I ran stiff plastic tubing from the ice maker water fill, it when all the way through with no blockage. I have replace water filter. Replaced water inlet valve. Two initial questions (I'm sure there will be more): 1. Can too high water pressure prevent the ice maker from filling? I haven't measure (need to buy a gauge) but the water pressure coming from water dispenser is strong. It will splash out of a small cup on initial press. And 2. in pic, what is the disconnected green/yellow stripe wire, supposed to be connected to? Ice maker has been random, but now has completely stopped refilling. Any ideas?
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Water does not go in the ice maker but when I put ice in there i can get my crush ice to come out of it. But it just will not make ice.
Rank: Guest
Originally Posted by: Guest  Water does not go in the ice maker but when I put ice in there i can get my crush ice to come out of it. But it just will not make ice.
