sgomez61
#1 Posted : Friday, January 15, 2016 1:35:17 PM(UTC)
sgomez61
we bought this dryer from a private seller hooked it up washer works fine put cloths in the dryer and it is not drying i decided to run it with out cloths in it and it gets really hot. i'm confused also i noticed that on the inside of the dryer at the top were you open the door {not the very to the top of the door} there is a cut out that is about 2" x 3" so i don't know if there should be something there or if it is suppose to be an open hole we have looked up the manuel but it doesn't show the hole or anything that might go in that area.
Thank you
Sonja
Jeff / APP Team
#2 Posted : Friday, February 12, 2016 4:07:50 AM(UTC)
Jeff / APP Team
Hello sgomez61. It sounds like the venting system is clogged or kinked. You will need to check the vent and clean it out. Be sure and clean the vent pipe and the dryer air duct assembly. If the air flow is not good, the unit will retain moist air causing the clothes not to dry. Try running the unit with the vent unhooked from the back of the dryer and see if the dryer works properly.
Guest (4)
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
