christigers
#1 Posted : Tuesday, April 28, 2009 7:26:52 PM(UTC)
christigers
Any help is appreciated. I was changing the belt on a Maytag Performa Series Dryer Model # PYE2300AYW and the idler spring slipped off of one side of the idler arm. There is one side attached to the bottom of the idler arm. Where does the other end of the spring attach? I couldn't find any pictures or diagrams online that showed that in close detail. Thanks so much.
kayakcrzy
#2 Posted : Wednesday, April 29, 2009 4:21:12 AM(UTC)
kayakcrzy
I never pay attention to that spring, but it is either going to mount on the base of the dryer, or a creavace on the motor bracket. Tom ApplianceEducator.com
christigers
#3 Posted : Wednesday, April 29, 2009 4:40:20 AM(UTC)
christigers
Thank you for the response. There is a little hole in the floor of the dryer that looks like it is lined up in a way that the other end of the spring could go there. However, putting it there doesn't put any tension on the spring and the idler arm just lays on top of the wiring. If I put it there will the tension of the belt pull it up off of the wiring on the floor? Does that make sense?
#4 Posted : Wednesday, April 29, 2009 4:46:56 AM(UTC)
This may help
http://www.applianceaid.com/images/belt-config.JPG
Does not show where the spring hooks to but does at least show how it should be when tensioned.
kayakcrzy
#5 Posted : Wednesday, April 29, 2009 4:57:55 AM(UTC)
kayakcrzy
Did you look around the bracket the motor sits in? It is either there or the base. One or the other. If all else fails go to the "Maytag Service Library, and hit literature by model #, and then put in your model #, and see if you can down load the manual. Tom ApplianceEducator.com
christigers
#6 Posted : Wednesday, April 29, 2009 6:03:25 AM(UTC)
christigers
Great pic! Thanks so much.
#7 Posted : Wednesday, April 29, 2009 6:06:13 AM(UTC)
Glad it helped
lapinskk
#8 Posted : Saturday, January 23, 2010 2:36:26 PM(UTC)
lapinskk
I am having the same question. I would really like to hear what you figured out on this. Can you reply with the final solution?
Guest (4)
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
