Kath B
#1 Posted : Tuesday, April 28, 2009 3:50:16 AM(UTC)
Kath B
My dryer has begun squeaking intermittently and very loudly when I dry our clothes.
#2 Posted : Tuesday, April 28, 2009 4:03:43 AM(UTC)
Replacement parts for GE DVL223EB4WW | AppliancePartsPros.com
Could be any of the moving parts or part that the drum rides on BUT most likely it is the rear center support bearing.
Could be worn or could be all it needs is greasing. The grease dries out over time.
Open it up and check it. Note that the grounding ball bearing Item 1205 in the "Cabinet & drum" section like to jump out and play hide and seek so watch out for it. If the bearing and the support shaft/ball look good the clean them and re-grease using a high temperature grease.
Here is some additional help
http://www.applianceaid.com/dryers.html
kayakcrzy
#3 Posted : Tuesday, April 28, 2009 4:27:51 AM(UTC)
kayakcrzy
If the sound is coming from the rear, it will be the rear bearing kit. If the noise just started, you would probably get off, with justy putting a lithium greese, in the cup the drum fits in. The top needs to come up, and the front needs to come off, the belt needs to come off, and the drum needs to come out, all in that order. Tom ApplianceEducator.com
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
