21 Pages«<1617181920>»
Tucson Alan
#171 Posted : Wednesday, March 27, 2013 6:09:26 AM(UTC)
Tucson Alan
Get F9 when using self clean only on top oven. Also fan in control module is inop. Door lock motor seems to continue to run until error code shuts down. Not sure if inop fan caused overheat of motor or it is just two separate issues. Oven works ok to cook but top module seems to get much hotter than we remember. Model PT956BM3BB GE
Jbemom
#172 Posted : Wednesday, March 27, 2013 11:42:08 AM(UTC)
Jbemom
I have a double electric wall oven. Model #GBD307PRS01. Serial #XT2210725. It flashed an error of F2 E6 on the display then went blank. I can press buttons and hear a double beep but nothing comes on the display screen anymore. The oven will not power on either. From reading the post on here it seems as though I need to replace the control panel. However, there are several parts to the control panel. Would you know what part #I should order? Also, is there a special place to order from other than Whirlpool?
Thanks for your help!
johnnyhp
#173 Posted : Wednesday, March 27, 2013 2:05:21 PM(UTC)
johnnyhp
Getting F10 intermitently. I measured the Ohms on the sensor and its 1076 at room temperature. that seems to ne ok. How do I check the board or other sensor in the back?
#174 Posted : Wednesday, March 27, 2013 8:00:06 PM(UTC)
Hello Tucson Alan,
Would the cooling fan work in non-self-clean operation?
If it would not then check for 120 VAC to the motor while the control calls for heating in any mode.
Post the results.
Here are the breakdown diagrams and Parts for GE PT956BM3BB Wall Oven - AppliancePartsPros.com
#175 Posted : Wednesday, March 27, 2013 8:06:34 PM(UTC)
Most likely the problem is a bad control board (electronic part behind the control panel) but there is a small chance for the control panel (part with the keypad) to be bad as well. I would replace the control board first.
- The control board Part number: W10340941
#176 Posted : Wednesday, March 27, 2013 8:08:06 PM(UTC)
What is the complete model number of the oven?
johnnyhp
#177 Posted : Thursday, March 28, 2013 4:52:21 AM(UTC)
johnnyhp
#178 Posted : Thursday, March 28, 2013 2:22:57 PM(UTC)
The "F10" error code means "Runaway temperature". Per your report the temperature sensor checks OK. So the solution is to replace the Electronic Oven Control (EOC). It is recommended to replace it together with the overlay because it's adhered to the EOC. If you need the correct part number for the overlay, post the color of it.
- The EOC Part number: 316557118
Tucson Alan
#179 Posted : Tuesday, April 2, 2013 7:41:14 PM(UTC)
Tucson Alan
Voltage across Gray and w/r and w/b when oven on or self clean. No continuity though across fan leads
Tucson Alan
#180 Posted : Tuesday, April 2, 2013 7:43:24 PM(UTC)
Tucson Alan
Hello Tucson Alan,
Post the results.
Read more: http://forum.appliancepartspros...es-18.html#ixzz2PMtrILAY
http://forum.appliancepartspros.com
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9/25/2015 9:01:34 AM(UTC)
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 4/18/2013 7:46:23 AM(UTC)
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 9/10/2012 10:21:53 AM(UTC)
by fred jacoby 4/4/2012 9:44:17 AM(UTC)
by sigman 3/23/2012 9:08:14 AM(UTC)
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 12/11/2011 3:37:20 PM(UTC)
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 9/7/2010 5:56:53 AM(UTC)
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 6/1/2010 4:58:30 PM(UTC)
by emidgette 6/1/2010 4:56:50 PM(UTC)
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 9/1/2009 4:51:40 PM(UTC)
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 6/25/2009 5:47:37 AM(UTC)
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 1/14/2009 9:31:27 AM(UTC)
by cndybkr 9/29/2008 12:13:03 PM(UTC)
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 11/15/2007 6:43:00 PM(UTC)
