In the last 2 weeks I have gotten an F1, F3, and F5 on multiple occasions. What do they mean. The manual just says to call a repairman.
Was thanked: 3 time(s) in 3 post(s)
Those error codes are: "F!" means a problem with the control board, "F3" means the control board senses open oven sensor, and "F5" means the control failure. All three together definitely point to a problem with the control board. Unfortunately this part is no longer available. Looks like it's time for a new range.
Thank you Gene. Time to shop for major appliances. :(
