Get F9 when using self clean only on top oven. Also fan in control module is inop. Door lock motor seems to continue to run until error code shuts down. Not sure if inop fan caused overheat of motor or it is just two separate issues. Oven works ok to cook but top module seems to get much hotter than we remember. Model PT956BM3BB GE
Hi, I have a double electric wall oven. Model #GBD307PRS01. Serial #XT2210725. It flashed an error of F2 E6 on the display then went blank. I can press buttons and hear a double beep but nothing comes on the display screen anymore. The oven will not power on either. From reading the post on here it seems as though I need to replace the control panel. However, there are several parts to the control panel. Would you know what part #I should order? Also, is there a special place to order from other than Whirlpool?
Thanks for your help!
Getting F10 intermitently. I measured the Ohms on the sensor and its 1076 at room temperature. that seems to ne ok. How do I check the board or other sensor in the back?
Originally Posted by: Jbemom  Hi, I have a double electric wall oven. Model #GBD307PRS01. Serial #XT2210725. It flashed an error of F2 E6 on the display then went blank. I can press buttons and hear a double beep but nothing comes on the display screen anymore. The oven will not power on either. From reading the post on here it seems as though I need to replace the control panel. However, there are several parts to the control panel. Would you know what part #I should order? Also, is there a special place to order from other than Whirlpool?
Thanks for your help! Hi, Most likely the problem is a bad control board (electronic part behind the control panel) but there is a small chance for the control panel (part with the keypad) to be bad as well. I would replace the control board first. - The control board Part number: W10340941
Originally Posted by: johnnyhp  Getting F10 intermitently. I measured the Ohms on the sensor and its 1076 at room temperature. that seems to ne ok. How do I check the board or other sensor in the back? Hi, What is the complete model number of the oven? Gene.
Gene. 790.96112408
The "F10" error code means "Runaway temperature". Per your report the temperature sensor checks OK. So the solution is to replace the Electronic Oven Control (EOC). It is recommended to replace it together with the overlay because it's adhered to the EOC. If you need the correct part number for the overlay, post the color of it. - The EOC Part number: 316557118
Voltage across Gray and w/r and w/b when oven on or self clean. No continuity though across fan leads
