Hi guys, I have a Kitchenaide KERS807SSS01 that we accidentally spilled water onto the stovetop, which leaked into the electronics thus throwing errors. We opened up the front panel, used a hairdryer to dry both the membrane and display panel, vacuumed out the dust from the front circular vents below it and plugged it back in...no errors.
Yet now whenever we are baking something in the oven, the moment you open the door it throws a F2E1 stuck /shorted key error from the steam. Sometimes it shuts down automatically and you wait for the steam to clear FROM INSIDE the display! It almost seems as if the round holes above it that were clogged with dust are now clear but letting steam into the unit thus throwing errors because of the steam hitting it.
Was thanked: 3 time(s) in 3 post(s)
Very likely the membrane switch was damaged by the spilled water. You may want to order the new part from Appliance Parts Pros and give it a try. You have nothing to lose due to their very friendly return policy. The membrane switch Part number: AP6014094
Good luck and keep us posted. Gene.
Thanks for error code reference.
