Discuss
Oven Error Codes
 in
Hello Tucson Alan , Would the cooling fan work in non-self-clean operation? If it would not then check for 120
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
  #171 (permalink)
Old 03-27-2013, 10:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello Tucson Alan,
If it would not then check for 120 VAC to the motor while the control calls for heating in any mode.
Post the results.
Here are the breakdown diagrams and Parts for GE PT956BM3BB Wall Oven - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #172 (permalink)
Old 03-27-2013, 10:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Jbemom View Post
I have a double electric wall oven. Model #GBD307PRS01. Serial #XT2210725. It flashed an error of F2 E6 on the display then went blank. I can press buttons and hear a double beep but nothing comes on the display screen anymore. The oven will not power on either. From reading the post on here it seems as though I need to replace the control panel. However, there are several parts to the control panel. Would you know what part #I should order? Also, is there a special place to order from other than Whirlpool?
Thanks for your help!
Most likely the problem is a bad control board (electronic part behind the control panel) but there is a small chance for the control panel (part with the keypad) to be bad as well. I would replace the control board first.
- The control board Part number: W10340941
Here are the breakdown diagrams and Parts for Whirlpool GBD307PRS01 Wall Oven - AppliancePartsPros.com
__________________
  #173 (permalink)
Old 03-27-2013, 10:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by johnnyhp View Post
Getting F10 intermitently. I measured the Ohms on the sensor and its 1076 at room temperature. that seems to ne ok. How do I check the board or other sensor in the back?
What is the complete model number of the oven?
__________________
  #174 (permalink)
Old 03-28-2013, 06:52 AM
Junior Member
johnnyhp is on a distinguished road
Default
Quote:
  #175 (permalink)
Old 03-28-2013, 04:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The "F10" error code means "Runaway temperature". Per your report the temperature sensor checks OK. So the solution is to replace the Electronic Oven Control (EOC). It is recommended to replace it together with the overlay because it's adhered to the EOC. If you need the correct part number for the overlay, post the color of it.
- The EOC Part number: 316557118
__________________
  #176 (permalink)
Old 04-02-2013, 09:41 PM
Junior Member
Tucson Alan is on a distinguished road
Default
Voltage across Gray and w/r and w/b when oven on or self clean. No continuity though across fan leads
  #177 (permalink)
Old 04-02-2013, 09:43 PM
Junior Member
Default
Hello Tucson Alan,
Post the results.
Read more: Oven Error Codes
http://forum.appliancepartspros.com
  #178 (permalink)
Old 04-03-2013, 01:10 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sounds like the fan motor has gone bad.
- The fan motor Part number: WB26X10264
__________________
  #179 (permalink)
Old 04-03-2013, 05:07 PM
Junior Member
Default
Yup, thats what I figured, ordered one today.
  #180 (permalink)
Old 04-03-2013, 06:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep us posted please.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Similar Threads
GE Oven error codes BobChurch Oven Repair (including Ranges and Cooktops) 3 09-02-2009 07:58 PM
oven error display codes mdj11faith Oven Repair (including Ranges and Cooktops) 1 09-02-2009 07:24 PM
GE oven error codes bdeinhardt@aol.com Oven Repair (including Ranges and Cooktops) 5 07-03-2009 12:41 PM
oven error codes cndybkr Oven Repair (including Ranges and Cooktops) 3 10-18-2008 09:18 PM
Error Codes Whirlpool Oven brummel Oven Repair (including Ranges and Cooktops) 0 08-25-2008 01:27 PM
