3 Pages<123>
#11 Posted : 13 years ago
Hopefully the Model Number Locator will help.
AlohaJane
#12 Posted : 12 years ago
AlohaJane
Hi Gene,
My whirlpool model number is ED5FVGXSSOO . My problem is when the arm is left down water floods my freezer. It does not make it in to the ice maker at all. I can see that the water freezes in the line going to my ice maker and then floods my freezer. I end up with a frozen waterfall in the back of my freezer.
I am able to get cold water through the door.
Thanks for taking the time to help everyone!
Aloha,
Jane
#13 Posted : 12 years ago
Hello Jane,
Thank you for your good words.
Most likely the problem with your refrigerator is a bad water inlet valve on the back of the fridge. I also would recommend to make sure that the water feeding tube into the ice maker is not misplaced.
- The water inlet valve Part number: W10408179
AlohaJane
#14 Posted : 12 years ago
AlohaJane
Gene,
Thank you so much!
Aloha,
Jane:)
#15 Posted : 12 years ago
You are welcome Jane. Keep us posted.
BarbjG
#16 Posted : 12 years ago
BarbjG
My Ice won't come through the little door either. It builds up in the freezer door. Help?
#17 Posted : 12 years ago
Did the ice door open?
BarbjG
#18 Posted : 12 years ago
BarbjG
No it doesn't
#19 Posted : 12 years ago
Remove the dispenser panel and check the solenoid and air gate parts.
BarbjG
#20 Posted : 12 years ago
BarbjG
How do I do that?
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 12 months ago
Whirlpool Ice Dispenser Auger issue (Refrigerator & Freezer Repair)
by Daveh839 2 years ago
Whirlpool Ice Dispenser loud (Refrigerator & Freezer Repair)
by jbusbee83 3 years ago
kenmore/whirlpool ice dispenser auger motor bad ? (Refrigerator & Freezer Repair)
by bobvance 6 years ago
burning up Whirlpool ice dispenser motors (Refrigerator & Freezer Repair)
by dicktrickle88 10 years ago
Whirlpool Ice Dispenser Problem (Refrigerator & Freezer Repair)
by aggiezg05 11 years ago
Whirlpool Ice Dispenser not dispensing (Refrigerator & Freezer Repair)
by dileas 12 years ago
Whirlpool ice dispenser not working (Refrigerator & Freezer Repair)
by DIM62 12 years ago
Possible Whirlpool Ice Dispenser Leak (Refrigerator & Freezer Repair)
by DJosephSr 12 years ago
Whirlpool Ice Dispenser Repair Kit Compatibility (Refrigerator & Freezer Repair)
by wsb252 13 years ago
whirlpool ice dispenser (Refrigerator & Freezer Repair)
by randc 13 years ago
Whirlpool Ice dispenser door not working (Refrigerator & Freezer Repair)
by commo 14 years ago
Whirlpool Ice dispenser Freeze up (Refrigerator & Freezer Repair)
by tc88 15 years ago
Whirlpool Ice Dispenser Not Working After Relay Replaced?! (Refrigerator & Freezer Repair)
by davehorner 15 years ago
whirlpool ice dispenser chute door wont close (Refrigerator & Freezer Repair)
by tksnyder 16 years ago
3 Pages<123>
