bhbare
#1 Posted : Sunday, March 1, 2009 7:33:25 AM(UTC)
bhbare
Ok I get water from door fountain but Ice maker is not filling.
I assumed wrong that is was the solenoid's. (replaced both sets still inop)
The Ice maker will keep cycling (turning like its completed its cycle) but without water Im out of luck.
I think I may need to replace the fountain control board part#61005274.
Can anybody confirm this is the issue?
kayakcrzy
#2 Posted : Sunday, March 1, 2009 7:48:41 AM(UTC)
kayakcrzy
If the icemaker is cycling and there is no water, you might want to check where the water comes into the icemaker, it might be frozen solid right there, preventing the water from coming into the icemaker. You said that you replace the water valve, so that should be good. If the water is not frozen in the water tube at the icemaker, I will tell you a fool proof way to find out if the icemaker is bad, but you need a volt meter to tell. What you have to do is just take the screw out that holds the water valve in place, with the power off of course, and put your meter on volts, and take the 2 wires off of the solonoid that goes to the icemaker, and stick your meter leads in each terminal,(Make sure the nothing is hitting metal) and then go to the ice maker, and take the front off, and on the icemaker front, you will see holes with a letter next to it. Get a piece of wire, about 6 inches long, and strip back each end, about a half inch, and stick one end in the M hole, and the other in the N hole which is right next to it, and then plug in the refrigerator, and the ice maker will start a cycle. Once it does count to a slow 10, and pull the jumper wire out, and the ice maker will continue to run through a cycle. Then go to the back of the refrigerator, where your meter leads are in the wiring harness, and at the end of the icemaker cycle, it should read 120 volts. If not, you need a new icemaker, if so, you either have a frozen water line or, no water. Let me know what you find. Tom
bhbare
#3 Posted : Sunday, March 1, 2009 9:24:09 AM(UTC)
bhbare
Ok I check things out, im not getting voltage then ice maker cycles through. (no Ice build up in the water line)
I decided to take Ice maker apart to see what could be wrong.
One of the heater rods that makes contact with its connection onto the controler board was a bit sooty and appeared to have taken a surge.
I cleaned this contact off can't imagine what else is wrong with this maker. Maybe its a bad thermostat?
What on the ice maker switches on the ice maker water solenoid ? (the thermostat)
kayakcrzy
#4 Posted : Sunday, March 1, 2009 12:49:17 PM(UTC)
kayakcrzy
So, we have a new water valve. The water line is clear to the back of the icemaker, and you are saying that it looks like it has taken a surge. The best thing to do at this time is to replace the icemaker. The icemaker head does not come by itself on this refrigerator. Maytag only advises to replace the whole IceMaker. The part # is D7824706Q. If the heater rod were bad, that would not prevent the icemaker from running and filling it with water, but it would not heat the ice tray so the ejector arms, can go through the ice to eject it. The thermostat is working because you said that it does go through the cycle on it own, but does not fill. If you have water, and the new valve is good, it sounds like the circuit is open on the board to tell the water valve to open. That is why I told you how to check it for sure. Tom
bhbare
#5 Posted : Wednesday, March 4, 2009 3:19:26 PM(UTC)
bhbare
ok i should get my new ice maker tommorow.
However came home tonight and getting a clicking noise on and off every so ofter and stuff in freezer is going soft.
I think I'm going to need a new compressor starter relay.
Any thoughts anybody, or should I just cut my losses and get a new one (this one is about 7 years old)
kayakcrzy
#6 Posted : Thursday, March 5, 2009 3:33:36 AM(UTC)
kayakcrzy
Yes, replace the overload and relay on the compressor, and the start capacitor. If that does not do it, you would need a new compressor, which is pretty costly. I would not buy the icemaker, just yet. Lets see if we can get this compressor going. Also take a look at the condenser fan motor, and make sure it is working. Because if it died, it would make the compressor hot, and give it the condition of clicking off and on. Tom
bhbare
#7 Posted : Saturday, March 7, 2009 2:57:49 AM(UTC)
bhbare
Replace the overlad and relay switch, it came as a replacement assemble ($32)
I opened the old overload part and litterly the parts poured out of it ( id call that a clue). Frige and freezer cooling and acting normally again.
Received replacement Ice maker same day replaced it and with 24 hours I have a full bin of ice.
$59 bucks for the ice maker from Just Ice Makers Home Page
Great guy, superior responce to questions even called back to change shipping option to save me a couple bucks.
Found the ice maker link off e*b*a*y he directed me to this other web site saved everbody some money.
kayakcrzy
#8 Posted : Saturday, March 7, 2009 5:16:19 AM(UTC)
kayakcrzy
There you have it. Tom www.applianceeduicator.com
Ice Maker not filling with water. Water dispenser works. Kenmore Elite (Refrigerator & Freezer Repair)
by jeffrich12 1/21/2023 9:13:34 AM(UTC)
Ice maker not filling with water (Refrigerator & Freezer Repair)
by bdaddy711@aol.com 7/13/2016 6:00:46 PM(UTC)
KitchenAid Standalone Ice Maker Not Filling With Water After a Few Cycles (Refrigerator & Freezer Repair)
by jessep28 8/4/2014 2:58:30 PM(UTC)
Whirlpool GSS26C5XXY00 ice maker not filling with water (Refrigerator & Freezer Repair)
by amain 11/5/2012 12:35:22 PM(UTC)
Ice Maker Not filling with water (Refrigerator & Freezer Repair)
by sooscreek 9/7/2012 12:24:44 PM(UTC)
Ice Maker not filling with water, dispenser works fine (Refrigerator & Freezer Repair)
by RobinM3 11/15/2011 8:57:12 AM(UTC)
GE Monogram Ice Maker not filling with water (Refrigerator & Freezer Repair)
by apfander 7/16/2011 10:23:07 AM(UTC)
Amana Ice Maker not filling with water (Refrigerator & Freezer Repair)
by dlstorch 5/6/2011 8:20:07 AM(UTC)
Ice Maker not Filling with water (Refrigerator & Freezer Repair)
Belarus rmoorhou 10/1/2009 4:17:41 PM(UTC)
by AlphaBob 5/12/2009 10:02:45 AM(UTC)
Belarus dp860 4/20/2009 6:15:04 PM(UTC)
by xochi 10/17/2007 2:04:24 PM(UTC)
