2 Pages12>
George Madden
#1 Posted : Tuesday, November 22, 2011 9:19:12 AM(UTC)
George Madden
The warning hot light will not go out at all on the small burner on the left rear.
George Madden
#2 Posted : Tuesday, November 22, 2011 9:20:24 AM(UTC)
George Madden
The warning hot light will not go out at all on the left rear small burner.
#3 Posted : Wednesday, November 23, 2011 2:54:17 AM(UTC)
Here are the parts. Be sure to specify which burner is gone if you order from them.
Replacement parts for KENMORE 66595022100 | AppliancePartsPros.com
Sounds like the normally open side of the limiter on the element is shorted.
File Attachment(s):
95022100.pdf (342kb) downloaded 1 time(s).
George Madden
#4 Posted : Wednesday, November 23, 2011 3:57:58 AM(UTC)
George Madden
Thanks very muvh for your help, today the light has gone out. Switch sticking?.
#5 Posted : Wednesday, November 23, 2011 4:26:25 AM(UTC)
[COLOR="DarkRed"]Switch sticking?[/COLOR]
Yes that would be my guess.
Often when contacts go the start by pitting and eventually weld themselves together permanently.
Odds are that it will happen again, but you can never tell so perhaps the problem will never reappear.
I will keep my fingers crossed.
George Madden
#6 Posted : Wednesday, November 23, 2011 4:30:22 AM(UTC)
George Madden
Switch sticking?
Thanks again for your help. Is this switch built into the glass top burners or is it separate. I've had to replace a couple of the burner control Switches a couple years ago.
#7 Posted : Wednesday, November 23, 2011 4:33:06 AM(UTC)
[COLOR="DarkRed"]Is this switch built into the glass top burners or is it separate.[/COLOR]
I believe it is built into the element assembly.
George Madden
#8 Posted : Wednesday, November 23, 2011 4:38:16 AM(UTC)
George Madden
Can the element be purchased separate from the glass top, I hope. Is it easy to change. Parts are expensive, almost time for a new stove.
George Madden
#9 Posted : Wednesday, November 23, 2011 4:52:03 AM(UTC)
George Madden
Denman has and is beiign a great help to us.
#10 Posted : Wednesday, November 23, 2011 6:27:14 AM(UTC)
Yes the elements can be purchased separately.
Installing them does take some time but is not that difficult once you figure out how to raise the oven to.
Just be sure to unplug the unit when working on it.
240 volts is lethal!!!
The unit is actually made by Whirlpool.
Here is a link to a site with lots of appliance manuals.
Download Manager - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
I do not have a Sears to Whirlpool cross reference so cannot be sure the following matches your unit.
That is why I gave the above link to the site. You may be able to figure out which manual matches you unit.
Here is the manual which I think may be close.
http://appliancedigest.com/index.php?/files/go/c1e3482d1a085c7409157d688afe864e/whirlpool-roper-estate-free-standing-electric-range-with-self-clean-service-manual
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
Kenmore Electric Range power issue (Oven Repair (including Ranges and Cooktops))
by chrei 9/11/2020 5:31:55 PM(UTC)
Kenmore Electric Range (Oven Repair (including Ranges and Cooktops))
by avengers522 3/6/2018 9:23:37 PM(UTC)
Kenmore electric range clock will not stay on (Oven Repair (including Ranges and Cooktops))
by zooeyhall 11/7/2015 5:28:16 PM(UTC)
by galensdad 10/1/2014 6:59:27 AM(UTC)
kenmore electric range wont heat (Oven Repair (including Ranges and Cooktops))
by tf78933 7/31/2014 2:44:42 PM(UTC)
Kenmore electric range oven not heating (Oven Repair (including Ranges and Cooktops))
by curtis1512 2/27/2014 2:07:20 PM(UTC)
kenmore electric range (Oven Repair (including Ranges and Cooktops))
by jeannieg 10/20/2013 8:27:41 PM(UTC)
Kenmore Electric Range doesn't reach temperature (Oven Repair (including Ranges and Cooktops))
by bilalian1 11/21/2012 12:13:39 PM(UTC)
by wcarter 8/14/2012 1:22:25 PM(UTC)
Kenmore Electric Range wired wrong (Oven Repair (including Ranges and Cooktops))
by njranger 3/15/2012 5:06:28 PM(UTC)
Kenmore Electric Range - F10 Error (Oven Repair (including Ranges and Cooktops))
by blackwidow71 6/19/2011 3:02:24 PM(UTC)
Kenmore electric range. (Oven Repair (including Ranges and Cooktops))
by vns 1/11/2011 9:17:00 AM(UTC)
Kenmore Electric Range left element not workig (Oven Repair (including Ranges and Cooktops))
by Youjin 11/21/2009 7:39:48 PM(UTC)
Kenmore Electric Range: No Heat From Bake Or Broil Element (Oven Repair (including Ranges and Cooktops))
by john7 9/21/2009 3:42:34 PM(UTC)
2 Pages12>
