Neither the broil or bake element will turn on. As far as I can tell, only the convection element is turning on at all. Oven will heat to about 270 on a bake or convection setting and that takes about 3 hours. Power supply is good. All elements look fine and are testing fine. No power is being sent to the other 2 elements, regardless of which cook cycle you use.
