Model 790.95032503
The top burners work fine. The inside is not heating at all. No broiler either. I have good power at the stove. The stove is about 6 yrs old. The heating element light on the stove top doesn't light up either. It does when the stove top is on, not when the inside is on.
Curt
Bet your electronic oven control is bad.....
Originally Posted by: festeraddams  Bet your electronic oven control is bad..... Did you ever get you oven fixed and if so what did you have to do? Thanks Larry
