Youjin
#1 Posted : Saturday, November 21, 2009 7:39:48 PM(UTC)
Youjin
Just realize that the Left front and Left rear surface surface element are not working.
The oven (bake and broil are fine) and the Right front and rear surface elements are working good too.
It is thanksgiving party tomorrow and i have only half of the electric surface heating burners working
:( what do i do ? i open the back of the range and visually the connections look to be fine.
The electric range is about 1.5 years old
any help/suggestion greatly appreciated...thank you
Youjin
#2 Posted : Sunday, November 22, 2009 12:34:10 PM(UTC)
Youjin
hi...any suggestion ?
It is the cooktop surface element (burner) - the left side not working.
If there is a reset or something i can do immediately..pls help.
Thanksgiving party is tonite.
Youjin
#3 Posted : Monday, November 23, 2009 9:26:39 PM(UTC)
Youjin
sorry, any suggestions ?
This is a ceramic glass cooking surface. If the left side heating element is not working (right is fine), there is probably a switch or receptable that i can order and replace ?
Thanks much for help....
#4 Posted : Tuesday, November 24, 2009 2:03:02 AM(UTC)
Here is a wiring diagram
http://manuals.frigidaire.com/p...ingfield/316441485en.pdf
Sounds like a wire may have burned off or a track on the relay board.
Unplug the unit and check the wiring.
Also check the track on the relay board going to P7.
Sorry I could not find any more info on this unit.
