I am trying to replace the over light in the above stove. The manual says to remove the bulb cover by grasping the edge of the cover, then pull out and remove. I have tried to do that but cannot get the cover off.
Turn off the power to the unit and spray water around the cover to lubricate it. Wipe water completely after the cover removed (before turning power on).
