budwiser1938
#1 Posted : Thursday, November 6, 2008 2:23:46 PM(UTC)
budwiser1938
I am trying to replace the over light in the above stove. The manual says to remove the bulb cover by grasping the edge of the cover, then pull out and remove. I have tried to do that but cannot get the cover off.
#2 Posted : Friday, November 7, 2008 12:24:30 PM(UTC)
Turn off the power to the unit and spray water around the cover to lubricate it. Wipe water completely after the cover removed (before turning power on).
Oven light bulbs (Oven Repair (including Ranges and Cooktops))
by joea99 1/27/2023 3:17:03 PM(UTC)
GE JGB918 lower oven light constantly on (Oven Repair (including Ranges and Cooktops))
by shoihjelle 11/4/2022 12:04:00 PM(UTC)
Whirlpool gas oven lights but won't heat to temperature (Oven Repair (including Ranges and Cooktops))
by mikepol2 10/28/2021 5:13:06 AM(UTC)
Kitchenaid KGRS807SSS00 Intermittent Oven Lighting Issue (Oven Repair (including Ranges and Cooktops))
by Mrserc 9/12/2021 6:13:11 AM(UTC)
No Display or Oven Light - GE Monogram ZGP304NR4SS (Oven Repair (including Ranges and Cooktops))
by Furgus 8/22/2021 10:11:09 AM(UTC)
Can't Remove Oven Light Globes! (Oven Repair (including Ranges and Cooktops))
by CarolynE 3/12/2018 5:40:23 AM(UTC)
Oven light won't shut off (Oven Repair (including Ranges and Cooktops))
by Stuga 11/7/2017 5:35:39 AM(UTC)
Kenmore gas oven lights but won't get hot (Oven Repair (including Ranges and Cooktops))
by BonnieLC 5/14/2017 5:42:25 PM(UTC)
GE Monogram Oven ZET3038 (same as JT930) no display or oven light (Oven Repair (including Ranges and Cooktops))
by pacasey 6/19/2015 8:57:25 PM(UTC)
Lower oven light won't turn off (Oven Repair (including Ranges and Cooktops))
by Steve1717 4/2/2015 1:22:49 PM(UTC)
is the oven igniter supposed to go out after oven lights? (Oven Repair (including Ranges and Cooktops))
by dterrasi 12/6/2014 1:54:14 PM(UTC)
Jenn Air OVEN LIGHT WILL NOT SHUT OFF (Oven Repair (including Ranges and Cooktops))
by smylist 9/28/2014 7:52:50 PM(UTC)
Oven lights, both of them, not working (Oven Repair (including Ranges and Cooktops))
by adam2104 6/8/2014 7:32:58 AM(UTC)
frigidaire oven light lock is on oven is not locked (Oven Repair (including Ranges and Cooktops))
by juke12box 5/2/2014 6:34:13 PM(UTC)
Plug for oven light (Oven Repair (including Ranges and Cooktops))
by nicnicman 1/2/2014 4:26:06 PM(UTC)
