I have a Maytag Gemini Smoothtop Double Oven range. Says it is a Precision Touch 750 series. The small halogen oven light in the upper oven burned out. I replaced it. It will not shut off. I have shut the oven light switch off and on, off and on. I have turned the breaker on and off. The oven door switch goes in and out just fine. Anybody have an answer to this?
Groups: Expert
Did you change the light out with the range plugged in?
 1 user thanked ThatGuy for this useful post.
I did exxactly this. Is there a way to fix this?
