Joined: 8/22/2021(UTC) Posts: 0 ![Canada Canada](/Content/images/flags/CA.png) Location: BC
GE Monogram gas oven model number:ZGP304N R4SS
The LED front panel is not displaying anything. The oven light is not coming on when the door is open. The gas top is fully functional - the LEDs for the burner switches work along with the push button "task light" that illuminates the switches. The oven doesn't come on when the oven control knob is turned.
The breaker has been re-set and the electrical plug has been tested and verified to be fully functional.
If anyone can share the correct GE troubleshooting flow chart including proper voltages, i would be very grateful.
