I have a Thermador double oven and the lower oven light won't turn off. I tried to push the switch in manually and still doesn't turn off. I removed the panel to access the wires and disconnected the wires from the switch and still doesn't turn off. What is the next thing it could be and how do I troubleshoot it? Thanks
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hey there; In case anyone having trouble with this:
I had the same problem and thought my door light switch was broken.
Just didn't know how to turn off/on the lower oven light. Someone else had used the oven who apparently knew how to turn it on but left it on, or maybe they just turned it on by accident.
On mine, you need to select the lower oven as if you are going to turn it on or adjust temp, by pressing the "upper/lower oven" button. Then press the light button, which usually only toggles the upper oven light on/off. But now it does the same for the lower oven. Nothing broken. My light was on for over a month haha.
