Believe the door switch/plunger for my GE JBG918 (dual oven gas range) has failed but I can't find the correct part and information on how to change it out. The door switch that stopped working is for the lower (convention oven) and now that oven will not work because the control indicates that the door isn't shut.
Any help would be greatly appreciated.
