darrellhall
#1 Posted : Tuesday, November 4, 2008 4:28:11 PM(UTC)
darrellhall
My dryer heats some of the time and does not heat at others. I have noticed that this seems to happen when I am using the setting that requires the moisture sensor. It seems that I can turn the timer knob and the moisture sensor will flash on and off. If I use the timed drying setting, everything seems to heat ok.
Does this sound like I need to replace the moisture sensor?
kayakcrzy
#2 Posted : Wednesday, November 5, 2008 3:37:10 AM(UTC)
kayakcrzy
I would check the vent to the outside, and make sure you get a good strong air flow. Clean the vent hose in the back. Also if you guy's use dryer sheets, like bounce, you might want to clean the sensor, with an alchohol solution. Some times there is a build up on the sensor, and it does not sence properly. Tom ApplianceEducator.com
darrellhall
#3 Posted : Wednesday, November 5, 2008 12:19:27 PM(UTC)
darrellhall
Thanks very much for the help.
Guest (4)
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
