DarrelD
#1 Posted : Monday, January 31, 2011 1:09:02 PM(UTC)
DarrelD
My Bosch dryer WTE86300US will not operate. It has power to the control panel but the panel won't lite up and doesn't have a display.
robostixDTLA
#2 Posted : Saturday, April 23, 2011 9:17:58 PM(UTC)
robostixDTLA
I also have the same model and I cannot figure out why the dryer is acting like there is no power going to it.
I've cleaned out the lint and have tried to reset the high limit thermostat. The dryer was working fine for two months, and just a few days ago the inside light and the control panel stopped working.
A washer is connected to the dryer and the washer is working. I've also checked the plug coming into the dryer and it is getting 240v.
I hope someone knows of a fuse somewhere I haven't seen yet. I really don't want to replace the front panel.
DarrelD
#3 Posted : Monday, April 25, 2011 3:32:44 PM(UTC)
DarrelD
Check your door switch, if it is ok you might need a new control board....I got mine from Sears.
Guest (4)
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Dryer WOn't Run (Dryer Repair)
by wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
dryer won't run (Dryer Repair)
by dymetz62 1/8/2014 5:00:20 PM(UTC)
by pmclaughlin@apins.com 4/9/2013 11:18:38 AM(UTC)
by Ronald Walls 3/19/2013 1:09:09 PM(UTC)
by Ronald Walls 3/19/2013 1:06:28 PM(UTC)
by loumemoli 7/2/2012 1:33:54 PM(UTC)
dryer won't run but heats up fast (Dryer Repair)
by w. carroll 3/28/2012 8:22:26 AM(UTC)
Dryer Won't Run (Dryer Repair)
by paul888 1/16/2012 1:37:57 PM(UTC)
Dryer won't run after start. (Dryer Repair)
by clparks 4/28/2011 9:49:25 AM(UTC)
by tterry 3/29/2011 10:49:47 AM(UTC)
