My Bosch dryer WTE86300US will not operate. It has power to the control panel but the panel won't lite up and doesn't have a display.
I also have the same model and I cannot figure out why the dryer is acting like there is no power going to it.
I've cleaned out the lint and have tried to reset the high limit thermostat. The dryer was working fine for two months, and just a few days ago the inside light and the control panel stopped working.
A washer is connected to the dryer and the washer is working. I've also checked the plug coming into the dryer and it is getting 240v.
I hope someone knows of a fuse somewhere I haven't seen yet. I really don't want to replace the front panel.
Check your door switch, if it is ok you might need a new control board....I got mine from Sears.
