2 Pages12>
kilowat
#1 Posted : 18 years ago
kilowat
oven has quit working, the the clean cycle will work. i have taken the igniter out plug it into 110 volts it glows bright red almost white
can the igniter still be bad??
Admin / APP Team
#2 Posted : 18 years ago
Admin / APP Team
Rank: Administration
Groups: Guests
What happens when you turn the oven on and set it to BAKE? Does the igniter start to glow?
kilowat
#3 Posted : 18 years ago
kilowat
nothing, only the clean cycle will work ran that also
#4 Posted : 18 years ago
Set the control to bake, check the schematic, and check the bake output wire from the control, if no voltage, you probably have a bad control module. Before replacing, check the resistance of the oven sensor, if way off it's room temperature resistance( should be around 1Kohm) replace it. Click on your
Model # to get the part #.
kilowat
#5 Posted : 18 years ago
kilowat
thanks will try that, i was in the navy in 65/69 aviation electronic been long time
lol
kilowat
#6 Posted : 17 years ago
kilowat
got around to measuring the ohms on the digtal meter it reads .22 k ohms
#7 Posted : 17 years ago
Sounds bad, just order a new one by clicking on your model # and getting the part #.
kilowat
#8 Posted : 17 years ago
kilowat
the local maytag dealer had the igniter changed it out still want come on
#9 Posted : 17 years ago
You changed the oven sensor or the igniter??
kilowat
#10 Posted : 17 years ago
kilowat
changed igniter #12400035
i think i read the ohms on the igniter and and posted, not the oven sensor!!!
took out the oven sensor it read 1000 ohms
Crosley Gas Oven igniter? (Oven Repair (including Ranges and Cooktops))
by gospelguy 7 years ago
Confused about replacing oven igniter Frigidaire (Oven Repair (including Ranges and Cooktops))
by artemis 7 years ago
Oven Igniter will not activate (Oven Repair (including Ranges and Cooktops))
by MDThompson 8 years ago
Oven Igniter for Capri (Sears) Propane Stove (Oven Repair (including Ranges and Cooktops))
by BumpyKnuckles 8 years ago
is the oven igniter supposed to go out after oven lights? (Oven Repair (including Ranges and Cooktops))
by dterrasi 10 years ago
Oven igniter glows red but does not heat (Oven Repair (including Ranges and Cooktops))
by TeamCeisel 13 years ago
Oven igniter Magic Chef (Oven Repair (including Ranges and Cooktops))
by Mar4130 13 years ago
Bosch oven igniter repair (Oven Repair (including Ranges and Cooktops))
by soonerhokie 14 years ago
Replaced Oven Igniter Melted Wire Nut (Oven Repair (including Ranges and Cooktops))
by Edward A 14 years ago
oven igniter on, no heat (Oven Repair (including Ranges and Cooktops))
by alelessbee 14 years ago
GE Oven Igniter coil replacement (Oven Repair (including Ranges and Cooktops))
by jeffcorona 14 years ago
How do I replace the oven igniter on a GE XL44 Range? (Oven Repair (including Ranges and Cooktops))
by rwbarrett 14 years ago
Oven Igniter (Oven Repair (including Ranges and Cooktops))
by LCPierce 14 years ago
Tappan oven igniter installation (Oven Repair (including Ranges and Cooktops))
by Just George 14 years ago
Replace gas oven igniter (Oven Repair (including Ranges and Cooktops))
by JRhein 14 years ago
2 Pages12>
