2 Pages<12
kilowat
#11 Posted : Wednesday, October 24, 2007 2:52:22 AM(UTC)
kilowat
couldn't take the wife's stares and comments any longer, gave in, called the repair man.yep it has a igniter in the bottom very well hid, he replaced it, oven working.see how long it takes to get a pie now!!!
#12 Posted : Wednesday, October 24, 2007 5:38:44 PM(UTC)
In your post from 10/11/07 you wrought "the local maytag dealer had the igniter changed it out still want come on". So the new igniter was bad or ...
kilowat
#13 Posted : Thursday, October 25, 2007 6:20:24 AM(UTC)
kilowat
top was good that the one i changed out:mad: , the bottom igniter was bad after we changed out the bottom one it's working
thanks all
Guest (6)
Crosley Gas Oven igniter? (Oven Repair (including Ranges and Cooktops))
by gospelguy 1/18/2018 1:02:51 PM(UTC)
Confused about replacing oven igniter Frigidaire (Oven Repair (including Ranges and Cooktops))
by artemis 12/4/2017 9:24:14 AM(UTC)
Oven Igniter will not activate (Oven Repair (including Ranges and Cooktops))
by MDThompson 12/27/2016 4:05:57 PM(UTC)
Oven Igniter for Capri (Sears) Propane Stove (Oven Repair (including Ranges and Cooktops))
by BumpyKnuckles 11/26/2016 6:38:15 PM(UTC)
is the oven igniter supposed to go out after oven lights? (Oven Repair (including Ranges and Cooktops))
by dterrasi 12/6/2014 1:54:14 PM(UTC)
Oven igniter glows red but does not heat (Oven Repair (including Ranges and Cooktops))
by TeamCeisel 9/25/2012 4:21:07 PM(UTC)
Oven igniter Magic Chef (Oven Repair (including Ranges and Cooktops))
by Mar4130 8/14/2012 9:26:19 AM(UTC)
Bosch oven igniter repair (Oven Repair (including Ranges and Cooktops))
by soonerhokie 9/4/2011 11:27:12 AM(UTC)
Replaced Oven Igniter Melted Wire Nut (Oven Repair (including Ranges and Cooktops))
by Edward A 6/7/2011 3:44:07 PM(UTC)
oven igniter on, no heat (Oven Repair (including Ranges and Cooktops))
by alelessbee 4/28/2011 8:47:52 AM(UTC)
GE Oven Igniter coil replacement (Oven Repair (including Ranges and Cooktops))
by jeffcorona 1/6/2011 9:35:05 AM(UTC)
How do I replace the oven igniter on a GE XL44 Range? (Oven Repair (including Ranges and Cooktops))
by rwbarrett 12/20/2010 8:47:55 AM(UTC)
Oven Igniter (Oven Repair (including Ranges and Cooktops))
by LCPierce 12/9/2010 8:42:47 AM(UTC)
Tappan oven igniter installation (Oven Repair (including Ranges and Cooktops))
by Just George 11/24/2010 9:44:06 AM(UTC)
Replace gas oven igniter (Oven Repair (including Ranges and Cooktops))
by JRhein 11/15/2010 7:07:22 AM(UTC)
2 Pages<12
