No heat in oven. Broiler heats fine; stovetop burners work fine. Removed temp sensor probe and tested at 1.09k at room temperature. Was instructed to test amps of igniter (should be 3.3-3.6 I was told). Haven't had a chance to test that yet. But, if the amps check out, what is the next step?
Groups: APP Team
Hi. If the ignitor glows most likely it's not pulling enough amps to open the gas valve. Replace the ignitor Part number: WB13K21
