TeamCeisel
#1 Posted : Tuesday, September 25, 2012 4:21:07 PM(UTC)
TeamCeisel
No heat in oven. Broiler heats fine; stovetop burners work fine. Removed temp sensor probe and tested at 1.09k at room temperature. Was instructed to test amps of igniter (should be 3.3-3.6 I was told). Haven't had a chance to test that yet. But, if the amps check out, what is the next step?
Simon / APP Team
#2 Posted : Tuesday, September 25, 2012 6:31:53 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the ignitor glows most likely it's not pulling enough amps to open the gas valve. Replace the ignitor
Part number: WB13K21
