Hi Guys and Gals,
I just purchased a replacement oven burner ignitor. The replacement unit came with bare wires and wire nuts. The original seems to have push in plugs at the end of the wires. Does anyone know if I simply cut and strip the wires and use the wire nuts to splice into the original plugs? Also, does it matter what wire goes where?
Thanks, George
Hi everyone, No need to respond to this issue. Since I posted I discovered that others had the same question. Followed their solutions and figured it out.
Thanks, Just George
p.s. Have a Happy Thanksgiving
