kevin
#1 Posted : Friday, July 20, 2007 5:12:10 PM(UTC)
kevin
Dryer Runs Heats For 3 To 5 Min Stops Heating Keeps Running
Changed Main Switch , Thermal Fuse, Heating Element
Matt / APP Team
#2 Posted : Friday, July 20, 2007 5:24:32 PM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
Have you checked/cleaned all the duct work in the dryer. Also did you clean the vent from the rear of the dryer all the way outside?
kevin
#3 Posted : Friday, July 20, 2007 5:41:04 PM(UTC)
kevin
all duct work is clean all the way
inutel
#4 Posted : Sunday, July 22, 2007 4:00:28 PM(UTC)
inutel
it sounds like another gas valve coils went bad. Usually when they get bad they work for the first 15-30mins after you start the dryer then quit. then works again after restarting you dryer. then quits again and so on....
Open the access panel on your dryer, back or front of the dryer depends on what model. Let the dryer run and observe if the igniter glows, observe if gas valve opens resuting burner to lit. Observe for several cycles, if you noticed igniter to glow but no resulting flame from burner i would suspect solenoid coils are bad, easy to replace.
edit:
opss...you said heating element. must be electric dryer. my bad.
check thermostats for continuity.
Admin / APP Team
#5 Posted : Tuesday, July 24, 2007 11:07:06 AM(UTC)
Admin / APP Team
According to the model number (LGR4634EQ3) this is a gas dryer. Good answer, inutel. Welcome to the forum!
- Dryer gas valve coils
Wesley
#6 Posted : Thursday, July 26, 2007 7:15:49 AM(UTC)
Wesley
did you check the thermostats for continutiy should read 0 ohms with digital meter. You check them with out power and uninstalled. It is probably the lower temperature one because it cycles the element off and on. Good Luck
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
