kevin
#1 Posted : Friday, July 20, 2007 5:12:10 PM(UTC)
kevin
Dryer Runs Heats For 3 To 5 Min Stops Heating Keeps Running
Changed Main Switch , Thermal Fuse, Heating Element
Matt / APP Team
#2 Posted : Friday, July 20, 2007 5:24:32 PM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
Have you checked/cleaned all the duct work in the dryer. Also did you clean the vent from the rear of the dryer all the way outside?
kevin
#3 Posted : Friday, July 20, 2007 5:41:04 PM(UTC)
kevin
all duct work is clean all the way
inutel
#4 Posted : Sunday, July 22, 2007 4:00:28 PM(UTC)
inutel
it sounds like another gas valve coils went bad. Usually when they get bad they work for the first 15-30mins after you start the dryer then quit. then works again after restarting you dryer. then quits again and so on....
Open the access panel on your dryer, back or front of the dryer depends on what model. Let the dryer run and observe if the igniter glows, observe if gas valve opens resuting burner to lit. Observe for several cycles, if you noticed igniter to glow but no resulting flame from burner i would suspect solenoid coils are bad, easy to replace.
edit:
opss...you said heating element. must be electric dryer. my bad.
check thermostats for continuity.
Admin / APP Team
#5 Posted : Tuesday, July 24, 2007 11:07:06 AM(UTC)
Admin / APP Team
According to the model number (LGR4634EQ3) this is a gas dryer. Good answer, inutel. Welcome to the forum!
- Dryer gas valve coils
Wesley
#6 Posted : Thursday, July 26, 2007 7:15:49 AM(UTC)
Wesley
did you check the thermostats for continutiy should read 0 ohms with digital meter. You check them with out power and uninstalled. It is probably the lower temperature one because it cycles the element off and on. Good Luck
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
Belarus glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
