acekun
#1 Posted : Saturday, August 7, 2010 7:26:42 PM(UTC)
acekun
After our washer fills up with water, it stops. It does not agitate. Then it drains all the water.
We tried it a couple of times but it wouldn't work. So then we tried to put it just on spin to dry the clothes a bit before adding them to our dryer. The washer would spin the clothes, but instead of ending the cycle it would then add water.
Any help would be very appreciated. I don't know anything about washers and am not naturally very good at fixing things but I'm on a budget. Thanks in advance.
#2 Posted : Sunday, August 8, 2010 11:15:32 AM(UTC)
You might have a bad water level switch. Remove the tub end of the plastic hose that goes to it and blow in it, might just fix it. Put it back, then check and see if that fixed it, post results.
acekun
#3 Posted : Sunday, August 8, 2010 8:25:34 PM(UTC)
acekun
That worked! Thanks for your help, I really appreciate it.
#4 Posted : Monday, August 9, 2010 12:16:12 AM(UTC)
If it was "stuck", I would force some vinegar down the tube with a turkey baster and dump some in the tub, to clear out soap residue.
Guest (4)
Washer does not agitate (Washer Repair)
by ccastr1 8/1/2013 7:21:27 PM(UTC)
Washer does not agitate on regular cycle (Washer Repair)
by Volpone 7/13/2013 12:49:46 PM(UTC)
Washer does not agitate or spin (Washer Repair)
by rags1 5/3/2013 12:42:16 PM(UTC)
Washer does not agitate properly (Washer Repair)
by DickMig 2/24/2013 5:34:47 AM(UTC)
Whirlpool washer does not agitate or spin (Washer Repair)
by rkgeorges 12/9/2012 9:47:35 PM(UTC)
Washer does not agitate or spin but drains (Washer Repair)
by howardscott 10/8/2012 2:08:32 PM(UTC)
by Darrell Jenkins 3/27/2012 12:39:10 PM(UTC)
by jvd819 12/11/2011 10:38:39 AM(UTC)
by sheliahiro 10/27/2011 6:08:13 AM(UTC)
Washer does not agitate in Gentle cycle (Washer Repair)
by malgase 5/7/2011 3:05:43 PM(UTC)
ge washer does not agitate or spin (Washer Repair)
by brunac10 1/5/2011 6:12:03 AM(UTC)
by nomadx 10/20/2010 6:49:24 PM(UTC)
by Tbecker 9/6/2010 2:04:03 PM(UTC)
Washer does not agitate, spin or drain (Washer Repair)
by nun4joy 4/21/2010 2:27:28 PM(UTC)
GE Washer does not agitate or spin (Washer Repair)
by Tammy2006 2/7/2010 7:40:57 PM(UTC)
