trying to replace the blower wheel on ge dryer - do i cut off the circle at the front of the blower to remove it or just remove the clamp at the back of the base between the motor and wheel cover?
Joined: 2/29/2008(UTC) Views messages in topic : 19,638
A model number may helps help you.
Some just pull straight off.
Some unscrew (left hand thread) Often these have to be broken to remove them.
Some have a screw (often an allen key) that holds the blower to the motor's shaft. |
THIS FORUM IS DEAD!!!!!!! |
