trying to replace the blower wheel on ge dryer - do i cut off the circle at the front of the blower to remove it or just remove the clamp at the back of the base between the motor and wheel cover?
A model number may helps help you.
Some just pull straight off.
Some unscrew (left hand thread) Often these have to be broken to remove them.
Some have a screw (often an allen key) that holds the blower to the motor's shaft. |
THIS FORUM IS DEAD!!!!!!! |
