My electric dryers element comes on for a few seconds when the timer is turned to a time/on position even with the door open and the start switch not activated. It then gose back off then a few minutes later it comes back on for a few seconds. The dryer works fine when it gets to the off positions it cuts off and doesn't come on until the timer is moved to on. First questions I have is this normal and if not what could be the problem.
Shannon
Here are the parts Replacement parts for WHIRLPOOL REX5634KQ1 | AppliancePartsPros.comHere is a wiring diagram http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf[COLOR="Blue"] First questions I have is this normal and if not what could be the problem.[/COLOR] No it is not normal, you should never have heat without the motor/blower running. There are a couple things that could do this but the most likely is a grounded element. The element has sagged or broken and is touching the case/frame. Check the heating coil. Unplug the unit and both wires to the coil. Check it with a meter, should be around 10 ohms. Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. If you do not have a meter unplug the units and the heater assembly and check it visually. you will probably be able to see the problem with the coil. |
THIS FORUM IS DEAD!!!!!!! |
