ee.dan
#1 Posted : Sunday, February 28, 2010 8:41:03 AM(UTC)
ee.dan
Ran out of ice yesterday. Ice tray was bone dry. Water dispenser continued to work properly. I checked the intake water line and discovered a slow leak where it connects to the refrigerator. I tightened the brass screw but still had the slow drip. The line is not cracked. Can anyone suggest a fix before I call for repairs?
Qtip
#2 Posted : Monday, March 1, 2010 7:40:55 PM(UTC)
Qtip
open the freezer and find the dime sized tube that feeds the water into the icemaker - is that tube frozen solid? was the leak where the water line connects to the water valve or was the leak where the plastic line runs up the back of the fridge into the freezer?
ee.dan
#3 Posted : Tuesday, March 2, 2010 2:38:44 AM(UTC)
ee.dan
Dime sized feeder tube was indeed frozen. I will thaw today w/hair dryer. The leak was where the plastic line meets the freezer. No cracks found in the line. Thanks for pointing me in the right direction. I'll let you know if thawing solves the problem. Should I expect recurrence or might this have been a "one time" problem? We have had the refrigerator since 2001 without any problems.
Qtip
#4 Posted : Wednesday, March 3, 2010 5:53:39 PM(UTC)
Qtip
the frozen filler tube indicates that the water valve doors are not closing all the way causing drops of water to drip down the fill tube slower than normal which is making it freeze in that tube 1 drop at a time. replacing the water valve will fix that problem. it was leaking at the connection by the freezer because that tube was frozen and the water had to go somewhere!
Guest (6)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KitchenAid KFIS27CXMS3 ice maker Leaking (Refrigerator & Freezer Repair)
by Scott1969 2/15/2021 10:39:41 AM(UTC)
Whirlpool WRF535SMBM00 Bottom Freezer Ice Maker Leaking - Water Adjustment (Refrigerator & Freezer Repair)
by brytyhokie 12/10/2019 3:10:24 PM(UTC)
Whirlpool Ice Maker Leaking (Refrigerator & Freezer Repair)
by WayneLee 3/7/2019 6:18:13 AM(UTC)
Frigidaire Refrigerator Ice Maker leaks (Refrigerator & Freezer Repair)
by TNPutter 7/31/2017 3:40:08 AM(UTC)
Ice Maker Leaking a lot (Refrigerator & Freezer Repair)
by agdodge4x4 4/19/2016 8:07:56 AM(UTC)
Ice maker leaks water,no cracks new part added (Refrigerator & Freezer Repair)
by charlieamering@yahoo.com 11/16/2015 5:57:31 AM(UTC)
LG Refrigerator Ice Maker Leaking (Refrigerator & Freezer Repair)
by jimdeprado 4/17/2014 5:06:08 AM(UTC)
ice maker leaking.... not the usual problems (Refrigerator & Freezer Repair)
by killermrob83 10/8/2013 4:30:56 PM(UTC)
GE Profile PSS26NG Arctica - Ice Maker leaking (Refrigerator & Freezer Repair)
by jimatx 12/11/2012 6:24:01 AM(UTC)
Water Supply to Ice Maker Leaking (Refrigerator & Freezer Repair)
by Salt1972 9/30/2012 5:46:09 AM(UTC)
Ice maker leaks inside freezer (Refrigerator & Freezer Repair)
by Rob0702 9/27/2012 4:13:38 AM(UTC)
Ice Maker leakes (Refrigerator & Freezer Repair)
by ajc54 7/24/2012 6:13:20 AM(UTC)
Kenmore ice maker leak, tried everything! (Refrigerator & Freezer Repair)
by Bgmwd 7/6/2012 6:35:14 PM(UTC)
Amana ASD2626HES ice maker leaks water over the side no stop (Refrigerator & Freezer Repair)
by igorelik 5/4/2012 9:01:45 AM(UTC)
