Hi, I have a large ice build up on the shelves inside my freezer. Is there a common gasket or something that causes this? Should I replace the whole Ice make assembly?
Thanks!!
Groups: APP Team
Hi. Check the fill tube position in the icemaker. If it's not causing splashing - then replace the icemaker Part number: 5303918344
