SQP
#1 Posted : Sunday, October 18, 2009 6:01:46 PM(UTC)
SQP
When I push the start button nothing happens. There is no light inside the dryer either. I turned the fuse on and off an couple of times and no change.
#2 Posted : Monday, October 19, 2009 4:26:23 AM(UTC)
Check at the unit to be sure you have the correct power.
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral should be 120 volts.
Sounds like you have lost half the line as normally the motor and the light use the same side of the line.
The door switch is Normally Closed power to the light and Normally open power to the motor.
SQP
#3 Posted : Sunday, October 25, 2009 11:14:39 PM(UTC)
SQP
My husband checked the outlet and it's working correctly. The breaker is also working. The problem seems to be with the dryer.
Thank you so much for your time.
#4 Posted : Monday, October 26, 2009 1:48:23 AM(UTC)
Control panel replacement parts for ADMIRAL LNC7764A71 | AppliancePartsPros.com
I cannot find a wiring diagram for this unit. If you do not have it look in the control console, they like hiding it in there.
Try different settings/cycle types to see if it will start.
Though on most dryers the interior light is not wired through the timer, it is worth a shot.
Check that a wire has not burned off at the terminal strip in the machine.
Next check the door switch
After that check the thermal fuse on the heater.
Here is a good site with basic dryer help
http://www.applianceaid.com/dryers.html
Guest (5)
Kenmore Elite dryer won't run... (Dryer Repair)
by J C Jones 9/11/2021 9:09:42 AM(UTC)
Kenmore Dryer won't run (Dryer Repair)
by gman536 3/14/2021 3:37:08 PM(UTC)
Dryer won't run unless start button is held down - no heat (Dryer Repair)
by jstrefeler 9/24/2017 12:10:11 PM(UTC)
Dryer WOn't Run (Dryer Repair)
by wstvpawjr13 5/14/2017 12:23:41 PM(UTC)
Dryer won't run after releasing the on button (Dryer Repair)
by Heathers1988 11/9/2016 4:20:53 PM(UTC)
Amana Dryer won't run (Dryer Repair)
by Paige Tremblay 1/26/2014 6:06:08 AM(UTC)
dryer won't run (Dryer Repair)
by dymetz62 1/8/2014 5:00:20 PM(UTC)
by pmclaughlin@apins.com 4/9/2013 11:18:38 AM(UTC)
by Ronald Walls 3/19/2013 1:09:09 PM(UTC)
by Ronald Walls 3/19/2013 1:06:28 PM(UTC)
by loumemoli 7/2/2012 1:33:54 PM(UTC)
dryer won't run but heats up fast (Dryer Repair)
by w. carroll 3/28/2012 8:22:26 AM(UTC)
Dryer Won't Run (Dryer Repair)
by paul888 1/16/2012 1:37:57 PM(UTC)
Dryer won't run after start. (Dryer Repair)
by clparks 4/28/2011 9:49:25 AM(UTC)
by tterry 3/29/2011 10:49:47 AM(UTC)
