I have a Maytag Dryer Model # MED5820TWO that is only 2 years old and when I set it on the sensor side to dry clothes it dries them but doesn't power down to shut off. I am wondering if it is the sensor or the timer? My husband took the back off and we blew any lint and dirt out that we could see. We want to do the repairs ourself but don't want to order parts we don't need.
Thank you
If the timer advances in the timed cycle but not in the auto cycle, the problem is most likely in the sensor.
I cannot guarantee you that replacing the sensor will fix it (that is the problem with on-line Forums, we are just not present at the machine) but it is highly likely that it will.
Good luck.
Find the wires that go from the sensor to the control board. Disconnect the wiring harness connector from the board and put a continuity tester on the corresponding connector contacts. Place a damp cloth on the sensor. You should get continuity. If so, replace the board. Part number: AP3713177
Originally Posted by: sidfink43 If the timer advances in the timed cycle but not in the auto cycle, the problem is most likely in the sensor.
Good luck. :D Thank you, you were right and the Maytag Tech and I ordered the part..
Originally Posted by: magician59 Find the wires that go from the sensor to the control board. Disconnect the wiring harness connector from the board and put a continuity tester on the corresponding connector contacts. Place a damp cloth on the sensor. You should get continuity. If so, replace the board. Part number: AP3713177
. :D You were right it was the circuit board and it has been ordered. Thank you very much.
