I'm trying to pull the old motor but i don't know how to detach it from the blower blade? HELP
What is the complete model number of the dryer?
The model# is 11086681700. It's a kenmore dryer but apparently is built by whirlpool
The blower wheel is threaded onto the motor shaft. The easiest way to remove it from the motor is remove the rear panel and the lint chute. Hold the blower wheel and using an adjustable wrench, turn the motor shaft CW.
Originally Posted by: pappymo1 I'm trying to pull the old motor but i don't know how to detach it from the blower blade? HELP I can not get the motor off the blower blades to replace the motor it is not wanting to turn on making a humming noise
Originally Posted by: alice 14 I can not get the motor off the blower blades to replace the motor it is not wanting to turn on making a humming noise What is the complete model number of the dryer? Gene.
