GaryDolman
#1 Posted : Monday, January 7, 2008 12:09:44 PM(UTC)
GaryDolman
do I have to to remove the evaporator motor to find out what model number I need for a GE Gss22jf side by side refrigerator? if I do will the refrigerator still work? I need to get one of these on order before the thing stops working completely
#2 Posted : Monday, January 7, 2008 5:02:50 PM(UTC)
Hi Gary,
The model number you provided is incomplete. It suppose to be a four more letters after "F".
Also, pros recommended to replace the main control board to if there is something wrong with the evaporator fan motor.
GaryDolman
#3 Posted : Tuesday, January 8, 2008 4:34:19 AM(UTC)
GaryDolman
There are only two places on this refrigerator that the model number appears, on the inside of the door in the refrigerator side and on the rear of the unit, if you have any idea where the full model number is please advise.
#4 Posted : Tuesday, January 8, 2008 8:07:01 AM(UTC)
Look on top inside the refrigerator.
GaryDolman
#5 Posted : Monday, January 14, 2008 10:16:59 AM(UTC)
GaryDolman
I looked inside on top, and found nothing. I will have to get the model number of the motor from the motor itself, I believe the evaporator motor is mounted inside the compressor compartment, accessed from the rear of the refrigerator, is this correct? I have the model number for the controller card.
#6 Posted : Tuesday, January 15, 2008 8:49:43 AM(UTC)
You are mixing the part number and the model number.
The evaporator fan motor is located in the freezer, behind the rear panel.
davidlevy
#7 Posted : Thursday, April 19, 2012 6:50:11 PM(UTC)
davidlevy
Hi Gary,
hello sir my is david i'm havig some problemswiring my evap fan part#frs3r4ew4
#8 Posted : Friday, April 20, 2012 1:51:26 PM(UTC)
Hi David,
Can you describe it more detailed please?
BTW, this motor comes with the installation instructions.
Refrigerator evaporator motor cycling on and off (Refrigerator & Freezer Repair)
by johncoach 12/31/2022 1:04:43 PM(UTC)
evaporator motor (Refrigerator & Freezer Repair)
by raphaelnackab 1/3/2018 3:25:15 PM(UTC)
Kenmore evaporator motor (Refrigerator & Freezer Repair)
by CletusT 8/12/2015 11:31:03 AM(UTC)
Evaporator Motor keeps failing (Refrigerator & Freezer Repair)
by Microt 1/22/2014 5:50:49 AM(UTC)
Evaporator Motor...I think (Refrigerator & Freezer Repair)
by tmcq 12/8/2013 8:50:30 AM(UTC)
Evaporator Motor Problem (Refrigerator & Freezer Repair)
by Tom Hawk 10/14/2013 3:29:02 PM(UTC)
evaporator motor won' run (Refrigerator & Freezer Repair)
by karlk 6/24/2013 5:32:59 PM(UTC)
No Power to Compressor & Evaporator Motor (Refrigerator & Freezer Repair)
by Marton 4/3/2013 8:32:58 PM(UTC)
Should I replace my evaporator motor (Refrigerator & Freezer Repair)
by tylerhead24 12/3/2012 2:44:29 AM(UTC)
Replacing GE refrigerator evaporator motors and motherboards (Refrigerator & Freezer Repair)
by richappy 5/18/2012 3:06:01 PM(UTC)
Strange evaporator motor voltages (Refrigerator & Freezer Repair)
by NeuroJoe 9/9/2011 2:51:25 PM(UTC)
Wiring Evaporator Motor (Refrigerator & Freezer Repair)
by Hook1948 8/24/2011 1:04:25 PM(UTC)
Evaporator motor fans (Refrigerator & Freezer Repair)
by lly45 6/13/2011 11:33:54 AM(UTC)
Evaporator Motor GE Hotpoint (Refrigerator & Freezer Repair)
by michiganj48091 5/21/2011 12:21:08 PM(UTC)
Replacing evaporator motor (Refrigerator & Freezer Repair)
by zeph317 4/21/2011 6:29:17 AM(UTC)
