karlk
#1 Posted : Monday, June 24, 2013 5:32:59 PM(UTC)
karlk
The compressor works, coils in freezer get cold, but the evaporator fan won't run. I removed the fan and tested with power directly to the motor and the fan works. What should I check next?
#2 Posted : Tuesday, June 25, 2013 2:14:41 AM(UTC)
A model number may help others help you.
Check across the fan for 120 volts in the unit when the compressor is on.
Sometimes a fan will run outside the unit when it has warmed up but will not run when cold.
karlk
#3 Posted : Monday, July 1, 2013 5:59:53 PM(UTC)
karlk
no power to the fan--what do I check now?
#4 Posted : Tuesday, July 2, 2013 7:22:41 AM(UTC)
