ALLAN MAH
#1 Posted : Sunday, January 6, 2008 9:40:09 AM(UTC)
ALLAN MAH
Oven does not work. Self clean cycle and broiler works fine. top works fine. Cannot bake, no heat.
#2 Posted : Monday, January 7, 2008 8:17:01 AM(UTC)
Hi Allan,
Most likely the problem with your oven is the bake igniter (#5 on the bake & broil break down diagram).
- The part number for the igniter is AP3008600
- Here are the break down diagrams for the Whirlpool range Model GW395LEGB4
Good luck.
Whirlpool Gas Range No Lights and Locked Door After Self-Clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 8:05:39 PM(UTC)
Whirlpool Gas Range won't light: gas valve shuts off after 1 or 2 seconds (Oven Repair (including Ranges and Cooktops))
by Drew42TX 4/22/2019 8:23:07 AM(UTC)
Whirlpool gas range. WFG320MOBW (Oven Repair (including Ranges and Cooktops))
by Heypit 1/14/2019 1:29:51 PM(UTC)
Whirlpool gas range accurate system super capacity 465 sf325peeq0 (Oven Repair (including Ranges and Cooktops))
by Losalgirl3 11/21/2018 7:21:07 PM(UTC)
Whirlpool gas range does not start in bake but works in broil (Oven Repair (including Ranges and Cooktops))
by blendq 1/2/2015 7:17:24 AM(UTC)
Whirlpool Gas Range (Oven Repair (including Ranges and Cooktops))
by DonJr. 6/10/2013 3:56:02 PM(UTC)
Whirlpool Gas Range F2 code (Oven Repair (including Ranges and Cooktops))
by Cookie NJ 10/10/2012 3:10:00 PM(UTC)
Tips for removing Whirlpool Gas Range Maintop / Cooktop (Oven Repair (including Ranges and Cooktops))
by user111 2/24/2012 11:05:35 AM(UTC)
whirlpool gas ranges (Oven Repair (including Ranges and Cooktops))
by mrbass 2/21/2012 12:32:57 PM(UTC)
Whirlpool gas range E2 F3 w/ 2 new sensors (Oven Repair (including Ranges and Cooktops))
by jeffmaaske 1/22/2012 1:25:55 PM(UTC)
Whirlpool Gas Range/Oven won't stay hot (Refrigerator & Freezer Repair)
by skwarner69 4/26/2011 1:14:25 PM(UTC)
Replacing Control Module on Whirlpool Gas Range (Oven Repair (including Ranges and Cooktops))
by NC_Lee 12/11/2010 12:49:22 PM(UTC)
Whirlpool Gas Range top Igniter not work. (Oven Repair (including Ranges and Cooktops))
by loveme4ever 11/2/2010 12:38:47 PM(UTC)
Whirlpool gas range oven will not ignite (Oven Repair (including Ranges and Cooktops))
by kamzuk 1/2/2010 2:59:23 PM(UTC)
New Whirlpool Gas Range Cook Top Ignitors Not Working (Oven Repair (including Ranges and Cooktops))
by stevenwwinters 11/27/2009 10:19:01 AM(UTC)
