DonJr.
#1 Posted : Monday, June 10, 2013 3:56:02 PM(UTC)
DonJr.
I self cleaned the oven, after it was done the display went blank and the oven door locked and will not open. What happened and how do I fix the oven?
Simon / APP Team
#2 Posted : Tuesday, June 11, 2013 8:34:27 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely there is an "open" thermal fuse, located at the back of the range. You will have to slide it out, unplug and possibly disconnect the gas line. Remove the rear cover panel and using the multimeter check the fuse for continuity.
The thermal fuse Part number: 8300802
If the fuse is OK, you should check the hi-limit thermostat
Part number: 9757807
Here are the breakdown diagrams and Oven parts for Whirlpool GW395LEPS00 - AppliancePartsPros.com
Please, post the results.
Simon.
DonJr.
#3 Posted : Tuesday, June 11, 2013 3:46:47 PM(UTC)
DonJr.
Simon,
The thermal fuse and the thermostat (975994) are bad. I am ordering the parts tonight. Hopefully this will fix it. Thank you and I will let you know how I make out.
Simon / APP Team
#4 Posted : Tuesday, June 11, 2013 4:28:34 PM(UTC)
Simon / APP Team
Groups: APP Team
What the 975994 is? You are missing one digit.
Simon.
DonJr.
#5 Posted : Tuesday, June 11, 2013 4:33:04 PM(UTC)
DonJr.
Sorry, the part number is 9759944. I believe it is a thermostat, fix.
Simon / APP Team
#6 Posted : Wednesday, June 12, 2013 9:03:04 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
This 9759944 thermostat is normally open and close on the temperature rise to turn on the cooling fan. If the cooling fan is turning on without any problem, then this thermostat is good.
Simon.
DonJr.
#7 Posted : Thursday, June 13, 2013 1:19:46 PM(UTC)
DonJr.
Simon,
Thank you so much. I put the new thermal fuse in this evening and the oven is working! Thank you and have a great night.
Simon / APP Team
#8 Posted : Thursday, June 13, 2013 1:29:02 PM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
Whirlpool Gas Range No Lights and Locked Door After Self-Clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/20/2023 8:05:39 PM(UTC)
Whirlpool Gas Range won't light: gas valve shuts off after 1 or 2 seconds (Oven Repair (including Ranges and Cooktops))
by Drew42TX 4/22/2019 8:23:07 AM(UTC)
Whirlpool gas range. WFG320MOBW (Oven Repair (including Ranges and Cooktops))
by Heypit 1/14/2019 1:29:51 PM(UTC)
Whirlpool gas range accurate system super capacity 465 sf325peeq0 (Oven Repair (including Ranges and Cooktops))
by Losalgirl3 11/21/2018 7:21:07 PM(UTC)
Whirlpool gas range does not start in bake but works in broil (Oven Repair (including Ranges and Cooktops))
by blendq 1/2/2015 7:17:24 AM(UTC)
Whirlpool Gas Range F2 code (Oven Repair (including Ranges and Cooktops))
by Cookie NJ 10/10/2012 3:10:00 PM(UTC)
Tips for removing Whirlpool Gas Range Maintop / Cooktop (Oven Repair (including Ranges and Cooktops))
by user111 2/24/2012 11:05:35 AM(UTC)
whirlpool gas ranges (Oven Repair (including Ranges and Cooktops))
by mrbass 2/21/2012 12:32:57 PM(UTC)
Whirlpool gas range E2 F3 w/ 2 new sensors (Oven Repair (including Ranges and Cooktops))
by jeffmaaske 1/22/2012 1:25:55 PM(UTC)
Whirlpool Gas Range/Oven won't stay hot (Refrigerator & Freezer Repair)
by skwarner69 4/26/2011 1:14:25 PM(UTC)
Replacing Control Module on Whirlpool Gas Range (Oven Repair (including Ranges and Cooktops))
by NC_Lee 12/11/2010 12:49:22 PM(UTC)
Whirlpool Gas Range top Igniter not work. (Oven Repair (including Ranges and Cooktops))
by loveme4ever 11/2/2010 12:38:47 PM(UTC)
Whirlpool gas range oven will not ignite (Oven Repair (including Ranges and Cooktops))
by kamzuk 1/2/2010 2:59:23 PM(UTC)
New Whirlpool Gas Range Cook Top Ignitors Not Working (Oven Repair (including Ranges and Cooktops))
by stevenwwinters 11/27/2009 10:19:01 AM(UTC)
PF error on Whirlpool Gas Range display (Oven Repair (including Ranges and Cooktops))
by jld1969 8/5/2009 2:34:02 PM(UTC)
