Hello. I need to replace my dented maintop on a WFG361LVS2 4-burner gas range. The part number is AP3120306. If you have any info on how to remove this part it would be greatly appreciated. I know the burners have to be unscrewed and removed. Will the maintop simply lift up thereafter or are there hidden hinges / screws that need to be removed first? Thanks!
^bump^
may be simple but I don't want to break anything. Please help if you can. Thanks.
