michiganj48091
#1 Posted : Saturday, May 21, 2011 12:21:08 PM(UTC)
michiganj48091
I just replaced the evaporator motor in my freezer. It seems to be working well for a couple of hours then the fan gets really loud. I reach in and pull the blade off and slide the small white cover back down and it is quiet again for awhile. Could I be missing a part or something?
#2 Posted : Sunday, May 22, 2011 1:06:59 AM(UTC)
The end bell grommets may be too loose, you can stiffen it up by adding rubber grommets to the existing ones, just trim them to fit. If that fails to fix it, replace the motherboard AP4436216
