johnecg14
#1 Posted : Thursday, May 6, 2010 4:56:42 AM(UTC)
johnecg14
hi good morning
my dryer work but doesnt heat
what i have to check first
#2 Posted : Friday, May 7, 2010 3:23:50 AM(UTC)
Replacement parts for WHIRLPOOL LER4634PQ1 29" Electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208576793.pdf
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker. The heater requires the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Unplug the unit and check the heater's thermal cutoff (Item 6 in Section 3) with a meter, should be 0 ohms. It is the one near the heater
Be sure to unplug one side of it when checking it.
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
