Dryer is loaded, put on auto dry, press care. Runs for 1.5 hrs does not shut-off. Clothes are damp. Half the load is removed, auto dry is left on but the press care is shut-off. After an hour, dryer does not shut-off automatically but clothes are very hot when removed.
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
What happens if you try it on TIMED DRY?
The Regular cycle from100 minutes to cool down then off work well but the cycles for cottons and wrinkle-free clothes will not turn off.
