When I push on button in nothing is happening. The door is closed tightly, electrical is fine, I hear the timer running.
The first thing I would check is the thermal fuse (#7 on the diagram). It has to be checked for continuity and replaced if open. It has to be replaced togehter with the cycling thermostat (#8). Make sure the dryer vent is clean all the way through the vent outlet. - The thermal fuse Part number: AP3132867
