mnunncliff
#1 Posted : Sunday, March 22, 2015 11:08:13 AM(UTC)
mnunncliff
the heating element glows brightly with door shut and switches off. We were getting some squeaking with heavy loads when we first started using it. Last night we got rattling noises in the back and the above heating element (we assume) problem. thanks to all.
#2 Posted : Monday, March 23, 2015 2:41:03 AM(UTC)
Parts for Frigidaire FEQ332ES0 Dryer - AppliancePartsPros.com
Here is a better copy of the wiring diagram.
http://manuals.frigidaire.com/p...f/Webster/134064000e.pdf
The first thing to fix is the element being on when it should not be on.
Note that if the element is not grounded then you will have to also replace the motor as the centrifugal switch on the motor should kill power to the elemet when the motor is not running.
As far as the ratting etc. you will have to open the unit up to find the cause.
Note that a common problem on these units is the rear drum support/bearing.
Below is a manual which may be helpful to you.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...e&id=80;t=1427107177
mnunncliff
#3 Posted : Monday, March 23, 2015 8:00:26 AM(UTC)
mnunncliff
thanks denman
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
